diyer2018
#1 Posted : Sunday, June 13, 2021 6:29:13 PM(UTC)
diyer2018
Hello,
The model number is: WM3987 HW
Hard reset didn't work (pressing the buttons on the display panel for 5 seconds and plugging back in).
I opened up the top panel and checked the noise filter input and output with a voltage tester pen and it seems ok.
Also opened up the main PCB and nothing seems to be burned. One of the terminals out of the Main PCB (with 3 wires - red, yellow and black) seems to have power when using the voltage tester pen. The red LED light is not turned on.
Should I try replacing the Main PCB?
Thank you.
ThatGuy
#2 Posted : Tuesday, June 15, 2021 12:26:28 PM(UTC)
ThatGuy
I don't know much about the LGs, but looking at the pictures of the two boards, both seem to have fuses. I would check them first. Follow the power.
https://www.appliancepar...01ec1006t-ap5251356.html
https://www.appliancepar...r38163341-ap5193084.html
