Charlie2210
#1 Posted : Sunday, November 3, 2013 1:10:52 PM(UTC)
Charlie2210
My washer machine stops during the rinse cycle and displays F3 E2 error. When I looked up the code it says its due to a bad water temperature sensor. I replaced this but it's still giving me the same error. can anyone help?
Charlie2210
#2 Posted : Sunday, November 3, 2013 2:51:45 PM(UTC)
Charlie2210
I just opened the cleanout on the drain pump and found coins, piece of plastic, and lint. I cleaned that out and was actually able to complete a full cycle. Fingers crossed that this has solved the problem.
Charlie2210
#3 Posted : Monday, November 11, 2013 7:28:37 AM(UTC)
Charlie2210
Still not fixed, error came again, going to call service repairman.
Mjoy4
#4 Posted : Monday, December 9, 2013 4:40:37 PM(UTC)
Mjoy4
Please help Charlie. Have exact problem let me know how u got fixed
VWL
#5 Posted : Tuesday, December 17, 2013 7:53:51 PM(UTC)
VWL
Having the same issue. Same F3 E2 error code. Repair guy replaced water temp sensor but the error code is still coming up when I try to wash clothes. (But the washer will run normally with nothing in it.) Have either of you figured out the problem?
Mjoy4
#6 Posted : Wednesday, December 18, 2013 3:14:59 AM(UTC)
Mjoy4
had to call service guy. he did not replace any parts at all. the only problem was a wire that was pinched to hard under a wire tie, he repaired the wire and was out in 10 min. works perfect now, 15 loads later . he said the error code does not always mean the sensors is bad, it just puts you in the right area of the washer to diagnose. hope thiss helps
Coloradowomyn
#7 Posted : Saturday, April 7, 2018 11:38:07 AM(UTC)
Coloradowomyn
I had the same e2 f3 error code. Had the repair person out several times. Replaced water sensor but still having problem. It was the black wire coming off of the sensor under a zip wire tie. Both of the black wires going to the sensor code under the zip tie were either broken or completely severed due to the zip tie too tight, the wire harness too short and the inherent wobble of the washer when operating causing breakage of wires. The only thing holding the ends together was the zip tie. I have a back ground in wire and electronics and repaired myself. Used butt end connectors. Works like new now!
Guest
#8 Posted : Monday, May 31, 2021 11:54:19 AM(UTC)
Guest
Having same issue. Where is the sensor located
