AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
GE side by side model GSS25KSTASS ice maker auger continues to run
Joined: 4/9/2021(UTC) Posts: 0  Location: North Carolina Thanks: 1 times
GE side-by-side model GSS25KSTASS
My ice maker auger continues to run after dispensing ice. It stops if I open the freezer door. I then press the light switch on the freezer wall and the auger starts running again. I had a repair person come out and look at it. He stated that I needed to send my control panel and have it re-wired (which I did). I reinstalled the door control panel and when I hooked up the auger attachment and pressed the light switch on the freezer wall the auger started turning again. I am at a loss of what to do next.
Joined: 7/27/2010(UTC) Posts: 1,395  Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
Have you checked the switch that gets pressed when you push a glass in to get some ice? it might be stuck on or broken internally. It could be a stuck relay on the main board located on the backside of the fridge. You could try gently tapping the relays to see if it will become unstuck. Just don't break them or the board. The little black boxes are relays. https://www.appliancepar...55x10942p-ap6048447.html
 1 user thanked ThatGuy for this useful post.
I reinstalled the ice maker auger one more time and everything works great. The remanufactured panel on the front of the freezer side works great. I do think the relays reset themselves from not using it and trying to reconnect a second time. I was fully expecting the same issue, but it didn't and for 200 bucks our frig is grEAT!! Originally Posted by: ThatGuy  Have you checked the switch that gets pressed when you push a glass in to get some ice? it might be stuck on or broken internally. It could be a stuck relay on the main board located on the backside of the fridge. You could try gently tapping the relays to see if it will become unstuck. Just don't break them or the board. The little black boxes are relays. https://www.appliancepar...55x10942p-ap6048447.html
