Joined: 10/11/2020(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: Colorado
My dryer works properly on the timed dry cycle, however it just keeps running on the auto cycles, the dryer does heat up, just stay on.
This is what I have done so far.
I have purchased certified used Timer and Control Board. I tested the timer by removing the black wire on (I think X) and tested continuity between X and T with the knob turned between the Wrinkle care and off and there was continuity.
I removed the cycling thermostat and tested for continuity and it does, I even put it on a skillet around 175-200 degrees and within about 20 seconds the continuity was lost.
I have removed the moisture sensing bars and cleaned them toughly with vinegar
I also took the drum out and tested I both safety switches in the back and they had continuity (just tested at room temp)
After all of this the dryer still will not turn of on the auto cycle. I may not be testing properly, so any input would be helpful.
