Joined: 9/12/2020(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: South Carolina
Hello all,
I am a beginner to fixing appliances. I have not experienced this before.
I have an amana BG21VW-P1325013WW . It was working just fine until I cleaned it and replaced the door seals. I really got it wet, and I let it sit for 2 days to dry.
The only things that work on it are the lights. I thought it was the dial thermostat, it wasn't.
I only have lights. The compressor doesn't run, the condenser fan doesn't work, and the evaporator fan doesn't work. I hear a slight click when I plug it in. I tested the compressor for resistance and it appears good.
I am wondering if this is a run capacitor issue? Maybe a start capacitor? Unfortunately, I spent too much money on it to give up on it now.
TIA.
Tom
I now have TWO Amana refrigerators doing the exact same thing. Anyone? Buhler?
I figured it out with the help of another forum. It was the defrost timer that was stuck/broken.
Tom
