Hi folks, well, I seem to have failed on the wiring.
CVE3400W – Jenn Aire Cook Top
Old switch: UTDP 411 New switch: 12002125
My new switch works and the element heats as it should. However, none of my other burners are now working, which I assume means they aren't getting power.
One thing different on my stove than what I'm reading is my main incoming hot power red line runs to this switch (LR) and is coupled with the red wire running to the next burner (LF) switch. They were both tied into the N position on the old switch.
The red line off the LR burner actually tied in through the RF burner switch.
So, my question is. Should I reconnect the two red lines I previously disconnected and hook them both into P2? That would leave the "2" position open on the new switch.
Thanks!
I replaced two right side burners, Rf and rr. Also my two infinite switch were BLOWN out. New dual is different. Zero instructions (marcone supplied)
Had to call an old colleague to figure out wiring. Well,,, it stopped tripping breaker as soon as I threw it on..BUT.. my elements won't glow at all. Zilch. Indicator ring(circles switch) comes on...but no heat Left burners both work properly. Completely stuck.
