Joined: 6/25/2020(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: LA
Under cabinet ice machine, stopped making ice. Fan not turning, compressor not turning on. Water is draining and flowing across the plate. -Cleaned evaporator -Replaced motherboard (didn't work). Put back old motherboard. -replaced start relay and overload (didn't work) -tested compressor windings (still good) -replaced fan motor (didn't work) -put back the new motherboard (didn't work)
What's next? Any ideas?
What do I need to test to figure this out?
Thanks! DS
It ended up being the control panel. Fixed!
