baechlem
#1 Posted : Tuesday, April 21, 2020 12:21:48 PM(UTC)
baechlem
The defrost coil is only getting around 20V in defrost cycle on an old GE fridge. I have replaced the thermostat, and tested both the coil and the timer for continuity; both passed. When I jump 3 & 4 on the harnes to the timer, the fans run. I put a 12g wire accross 2 & 3, and the heater coil still did not heat up. What else should I try?
Edited by user Tuesday, April 21, 2020 1:37:01 PM(UTC)  | Reason: Not specified
