TFGTech
#1 Posted : Tuesday, January 21, 2020 3:17:30 PM(UTC)
TFGTech
Canada
I am troubleshooting a dishwasher that will not fill
I removed the water inlet valve and it looks fine (filter not plugged)
When I tested the power connections with a volt meter I believe I am supposed to see 120 VAC when the dishwasher fills. I see 37 volts when I first start the cycle, but then it drops to 1 VAC when it is supposed to fill.
How do I troubleshoot from here?
The KitchenAid model I have has an electronic control panel. Does this mean the control panel is shot, or is there an easier fix?
