Joined: 1/9/2020(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png)
I have a GE fridge model# GTH18GBDGRWW. Recirculation fan started to make noise so I ordered replacement for part# WR60X10141. I received part# WR60X10346 which looks identical. After installation fan did not come on when condenser did. After checking installation I tapped the Fan and it started, now the fan will only run if it is tapped. Refridgerator works normally and does shut off once proper temperature is reached. Do I have the wrong part or do I have a control board issue?
Update: Just after I wrote this, fridge came on and so did the fan... I will continue to monitor the fan.
