Joined: 9/25/2019(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: MI
I went to get ice and found water and ice in the ice-cube bin. I checked the freezer temp and it was 6 degs F. I removed the front lower plastic cover and vacuumed whatever I could reach. It seemed to help and the freezer returned to zero degs. A week later, I went to get ice and found that all of the ice had melted and then refroze into 1 solid block. This has happened 3-4x in the past 2 months.
The fridge has always maintained a proper temp. Freezer occasionally gets warm but then refreezes.
1 of the seals on the refrigerator doors looks like it should be replaced, but the freezer seal looks fine. Before I spend close to $300 on 3 new seals, I wanted to check to see if anyone else has had this problem or any recommendations you may have.
Thank you!
