Adrian R.
#1 Posted : Tuesday, May 28, 2019 10:26:13 AM(UTC)
Adrian R.
We are getting an error code E3 on a Maytag Washer model# MAH8700AWW. We have replaced the motor and had the control board repaired. The wiring connection has been inspected and all appears to be good at the motor. One thing happening is if the drive belt is removed the washer will complete a cycle with no error codes. If the belt is reinstalled the error code returns when the motor attempts to operate? Any ideas of what could be causing this issue?
