lediaz
#1 Posted : Sunday, April 14, 2019 10:22:46 AM(UTC)
lediaz
Does any body happen to know the part number or name of the part in the picture? My washer is missing one as well as the 2 remaining are missing the little part the holds these bolt. Any help would be greatly appreciated.
https://m.imgur.com/gallery/ZA6kdAI
lediaz
#2 Posted : Sunday, April 14, 2019 3:34:14 PM(UTC)
lediaz
I believe the image didnt upload but this part is like a bolt and right below this is like a plastic cap that in case the bolt falls it falls inside the cap. The bolt is gold color and has a hole where in one end to hold it. If you remvoe the case of the washer and look at the bottom of the support there is this part.
lediaz
#3 Posted : Sunday, April 14, 2019 3:43:29 PM(UTC)
lediaz
Image, this link works fine. Any help will be really appreciated. Thank you.
https://imgur.com/IKevBjj
Edited by user Sunday, April 14, 2019 3:45:25 PM(UTC)  | Reason: Not specified
#4 Posted : Sunday, April 14, 2019 8:02:14 PM(UTC)
Why do you need this pin? This pin needed for transportation only. If you still need the part number, the complete model number of the washer would help.
lediaz
#5 Posted : Monday, April 15, 2019 9:08:03 AM(UTC)
lediaz
oh, are these the transportation/shipping bolts? I didnt know that. My washer is 7mwt96540 whirlpool and because of the issue my washer has I thought this might help. The problem is that it is moving and shaking a lot when spins; yes, I have replaced many many parts already (suspension pads AP3094373 and AP3094518, front legs, spring on rear leveling link, drive block, suspension springs, etc) I believe it moves because the rear right leg can't level due to rust so I am going to try to replace this part as well, but I thought it was moving as well because when the basket spins it moves uncontrolled (not in circle way, but more like eliptical) I havent replaced the balance ring which by the way, after I replaced the drive block now it is like scrapping the plastic inner tub.
I place 2 of these pins and tested it and the washer didn't move at all, but it was on a small load, usually when it moves and shakes worst is on medium, big or extrabig loads.
After all, I believe because of replacing so many things now the washer is worse. I will keep looking for a fix or may be think more seriously about getting a new one :(
#6 Posted : Monday, April 15, 2019 3:54:19 PM(UTC)
Looks like you are on the right track. The rusted rear leveling leg would definitely cause unbalance and shaking. The part number Part number: 285244
Part number: 285244
Repair video
