Maytag Model # MER5755QAQ In the middle of making dinner, I noticed my oven quit preheating. The cooktop elements and broiler were still working. I removed the plate over the baking element and saw that it was cracked and blistered in multiple places. It was in several pieces. I ordered and replaced the broken to bits baking element. Now the oven still will not heat and now the cooktop and broiler will not work either. The on indicator light no longer lights up. The clocks works and I can changes settings, but nothing actually happens. I've turned off and on the breaker and reinspected the connectors where I replaced the baking element. They weren't corroded or messed up in any way that I could see. I am at a loss because things that worked now don't and all I did was remove and replace the element. Help appreciated! Edited by user Tuesday, January 8, 2019 10:50:21 AM(UTC)
| Reason: Not specified
