Joined: 11/24/2018(UTC) Posts: 0 ![Australia Australia](/Content/images/flags/AU.png) Location: Adelaide
I confused and need some help.
I am in need of changing the Condenser Fan Motor on a Whirlpool 6ED20TKXGW02 fridge. The problem I am having is that the old fan was a Emerson 2198747 motor. When I check the diagram it lists the part as Part Number: AP3778691 which is a replacement for Part Number 8201703 (AP3778691) replaces 1065750, 2154639, 2154739, 2162066, 2162430, 2166664, 2166665, 2183401, 2188539, 2198746, 2198747.
However the fan I have is stamped on the back as CWLE (clockwise looking at the back of motor/ counterclockwise looking at shaft. (Old motor pulled hot air from the compressor) All the replacements listed seem to be CW (Clockwise at shaft - opposite to the motor I have). A clockwise motor would push air towards compressor, and I assume the blades would have to be replaced.
