Our front load LG washer is really loud and the drum is unbalanced during the spin cycle. I am also noticing a burning rubber type smell as it gets into the final spin. What would be causing it to do this? What should I look for to correct this? Any help would be appreciated!
Sorry, but you are not so lucky. LG should not even offer those parts, as it takes special hydraulic presses to install some of that. For anyone but the manufacturer them self you must replace the back half of the outer drum (I believe it is a 3045ER0008C in your case) which contains the installed seal and bearing, plus I'd recommend replacing the spider asm 4434ER0002A, as the shaft may be a bit worn where it contacted the seal and bearing, and you don't really want to go through all that work (at least 2 hours) only to have to do it again. A FixYa rating would be appreciated. Thanks. _____________ [COLOR="Black"]safe gun[/COLOR]
Joined: 1/3/2020(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png)
Originally Posted by: bainters ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Our front load LG washer is really loud and the drum is unbalanced during the spin cycle. I am also noticing a burning rubber type smell as it gets into the final spin. What would be causing it to do this? What should I look for to correct this? Any help would be appreciated! How was this resolved?
