retiredfornow
#1 Posted : Tuesday, March 27, 2018 12:51:15 PM(UTC)
retiredfornow
My sears whirlpool model 106.50592000 mfg in 2000 side-by-side refridge icemaker wont stop making ice. It has the optical shut off not the wire bar. When I slide the manual shutoff switch that blocks the infared signal to the receiver it doesnt stop the icemaker as it has in the past. I normally keep the manual switch closed as I dont use that much ice and dont want to make more than a half bucket at any time. Anyone know what component is at fault and what I need to replace? Thanks
ThatGuy
#2 Posted : Tuesday, March 27, 2018 1:51:04 PM(UTC)
ThatGuy
Its most likely this set of boards. They are supposed to sense the ice level and shut off the ice maker.
Whirlpool W10757851 Ice Level Power Control Board Kit - AppliancePartsPros.com
Or check Epay or Amazon. Prices are all over the place. part w10757851
