ttrueheart
#1 Posted : Sunday, March 25, 2018 2:59:31 PM(UTC)
ttrueheart
Okay, the gas cook top functions just fine. The display for the oven and broiler show the correct messages, ie function, temp and so on. But the oven and the broiler do not heat. Am I looking at new elements, or a control module problem.
ThatGuy
#2 Posted : Monday, March 26, 2018 6:13:06 PM(UTC)
ThatGuy
Did you just self clean recently? Many of these ovens have thermal fuse the can "open" and stop power from going to the elements. Part 37 on this diagram.
Parts for KitchenAid KDRP463LSS08: Oven Parts - AppliancePartsPros.com
Whirlpool WP8300802 Thermostat (tod) (temp.) Spst - AppliancePartsPros.com
ttrueheart
#3 Posted : Tuesday, March 27, 2018 12:01:05 PM(UTC)
ttrueheart
no, just recently installed. checked voltage at the junction box, getting 240. thermal fuse has good continuity, no burnt wires going to the elements. when i try to use the oven or broiler it seems to be acting normally, although the preheat light does not come on. thinking control panel.
Kitchenaid Oven range Superba kgsc308lss0 not heating up (Oven Repair (including Ranges and Cooktops))
by rattty 5/19/2024 6:51:16 PM(UTC)
Kitchenaid oven baking element replacement (Oven Repair (including Ranges and Cooktops))
by Rocky D 1/19/2023 5:12:04 PM(UTC)
KitchenAid Oven KEBS107SBL (Oven Repair (including Ranges and Cooktops))
by PapaThor 10/20/2021 12:10:45 PM(UTC)
KitchenAid oven doesn't get up to temperature (Oven Repair (including Ranges and Cooktops))
by mlaird 12/27/2019 7:29:00 AM(UTC)
KDRP467KSS08 / KDRP467KSS0 KitchenAid oven not working (Oven Repair (including Ranges and Cooktops))
by larrywick 10/18/2019 2:28:40 PM(UTC)
How to reinstall KitchenAid oven door (Oven Repair (including Ranges and Cooktops))
by tiggers13 1/18/2017 1:31:44 PM(UTC)
KitchenAid Oven, intermittent lighting (Oven Repair (including Ranges and Cooktops))
by ryancfields 3/27/2016 8:15:32 AM(UTC)
KITCHENAID OVEN DOES NOT LIGHt (Oven Repair (including Ranges and Cooktops))
by PCircenis 1/22/2016 8:17:28 AM(UTC)
Kitchenaid Oven Help (Oven Repair (including Ranges and Cooktops))
by ehenry 12/9/2015 3:59:14 PM(UTC)
kitchenaid oven no power and locked (Oven Repair (including Ranges and Cooktops))
by greg_gue 1/12/2015 12:50:02 PM(UTC)
Kitchenaid oven keeps shutting OFF (Oven Repair (including Ranges and Cooktops))
by jbili 10/16/2014 3:37:51 PM(UTC)
Kitchenaid Oven (Oven Repair (including Ranges and Cooktops))
by alicehec@aol.com 3/25/2014 6:04:29 PM(UTC)
KitchenAid Oven F1 E1 error (Oven Repair (including Ranges and Cooktops))
by bobu2 1/4/2014 4:39:33 PM(UTC)
KitchenAid Oven Won't Hold Temp (Oven Repair (including Ranges and Cooktops))
by bjjansen 1/2/2014 6:19:08 AM(UTC)
Recurring Kitchenaid oven hinge failure (Oven Repair (including Ranges and Cooktops))
by walterjdog 12/18/2013 3:03:08 PM(UTC)
