tbanks204
#1 Posted : 7 years ago
tbanks204
This unit is freezing up:
Replaced Defrost heater element
Replaced Defrost Thermostat
Unit is still Freezing up, it appears to run longer that normal, compressor will shut off if cold control turned down enough. otherwise this unit cools great and freezer works great. Any Suggestions, thoughts, Ideas on what to replace next assuming the new parts are working correctly? Thank You
ThatGuy
#2 Posted : 7 years ago
ThatGuy
Did you replace the defrost control board? Part 4388932
Whirlpool 4388932 Adaptive Defrost Control Board - AppliancePartsPros.com
Or do a search for it on Epay or Amazon.
tbanks204
#3 Posted : 7 years ago
tbanks204
No I have not, as it would be the most expensive repair.
tbanks204
#4 Posted : 7 years ago
tbanks204
I would not be opposed to doing so, but I can't be sure this was the culprit, or the temperature control thermostat, I guess I could replace both, the temp control is not overly expensive.
ThatGuy
#5 Posted : 7 years ago
ThatGuy
The temp. control is NOT part of the defrost system.
ThatGuy
#6 Posted : 7 years ago
ThatGuy
Take this no. and do a search on amazon. 4388932
Fridge side evaporator freezing up... (Refrigerator & Freezer Repair)
by steve1147 10 years ago
Evaporator freezing up (Refrigerator & Freezer Repair)
by Scoob 15 years ago
