I have a Kenmore 800 series electric dryer that Wont start in certain spots on the timer cycles. In timed dry mode, it only starts between 70 and 200 minutes, and shuts off at 20 minutes. In auto moisture sensing mode, it will only start in the More Heat selection, and shuts off at Normal Dry. In both, it will start in the Wrinkle Guard selection. Heat is good in all cycles. In Test mode, I get beeps for all of the tests except the timer test. Replace the timer? model number is 11069822801,
Joined: 7/27/2010(UTC) Posts: 1,395 Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
