I have a whirlpool top load washer. When running a load on a cycle it won't spin. Once the cycle ends I can set it to one of the spin cycles and works fine.
Joined: 6/13/2014(UTC) Posts: 781 Was thanked: 1 time(s) in 1 post(s)
A number of things could be wrong. (sorry for the late answer) First thing is get out the tech data sheet and go into diagnostic mode and see if there are any error codes..... Your tech data sheet is inside the case on the front panel in a ziplock type bag.
