I have a Maytag mav2755aww washer that has problems. I ran a load a couple days ago... after it filled, it had a loud banging sound when it was agitating. After that, it spun, but did not spin very well - left the clothes very wet. I tried to re-run the spin cycle, but the drum stopped spinning, just drained the water out (pump works), and the agitator spins instead.
I've checked the belt - OK - the motor - OK - the pump - OK - and checked the thrust bearing - think it's bad. I can't get the alignment arrow to come up between the min and max indicators - it's below the min indicator. Spinning the pulley clockwise turns the agitator; counter-clockwise it also spins the agitator.
I've ordered a thrust bearing kit, hoping that getting the thrust bearing where it needs to be will resolve the issue, but I have a sneaking suspicion the transmission or the brake assembly is toast. Is there a definitive way to test this before the thrust bearing kit goes in?
Joined: 7/27/2010(UTC) Posts: 1,395 Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
