txdutchman
#1 Posted : Sunday, January 28, 2018 8:18:27 PM(UTC)
txdutchman
Amana microwave model # RR 810
Mfg # P75592 2M
Sometimes it will blow the fuse when you open the door. Might work fine 20 times, then it will blow it the next time. Or might use it twice and then blow it again. Where do I start looking to fix this? Don't like new microwaves. This old one works better if I can keep it from blowing the fuse.
Thanks.
ThatGuy
#2 Posted : Monday, January 29, 2018 12:57:04 AM(UTC)
ThatGuy
I looked up these numbers RR-810 / P7559202M
Parts for Amana RR-810 / P7559202M Microwave - AppliancePartsPros.com
Parts for Amana RR-810 / P7559202M: Page 1 Parts - AppliancePartsPros.com
It should be a problem with the door interlock switch. part #
C8889905
I found one on Epay (you can't type the real name here)
Just search "switch C8889905"
txdutchman
#3 Posted : Monday, January 29, 2018 4:22:55 AM(UTC)
txdutchman
Thank you! I will give that a try!
