Hello everyone!
I would like to know where is located the power board, part # 9782437 on a KitchenAid Superba KERC607HBS8 model. I found a Repair Part List but the drawing is not really clear. Thank you in advance for any help.
Joined: 2/4/2020(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: Yo' mama's bedroom
Sorry this is 3 years late.. maybe it will help someone else.
It is under the right side panel. Remove the black screw in the middle of the floor bar(remove the drawer), then remove the two black screws on the back (that hold the side to the back) Open the door, pull the back of the side panel away from the frame, and tap it forward.
It will pop right off. There are tabs at the top front and bottom front that release it to the front.
The power board is at the bottom.
I JUST did this. My friend's oven will not heat, and I was looking for the relay. Found it next to the power board. The relay works fine. Now I am down to the temperature sensor or the power board itself... (not letting the BK BU VI RD wires connect to the left side 120 (they are connected to the right side 120 by the red wires and the relay)
