AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Kenmore washer won't fill won't run motor trips
Kenmore 600 series washer. Won't fill on any cycle. Motor overheats and trips thermal overload. To me it seems like a timer switch issue. Any suggestions? Timer switch ~ $50. Worth replacing?
Joined: 6/13/2014(UTC) Posts: 781 ![Man Man](/Themes/yafvision/male.gif) ![United States United States](/Content/images/flags/US.png) Was thanked: 1 time(s) in 1 post(s)
If you set timer to spin will the washer spin? Have you tried setting water temp to hot, warm then cold to see if that makes a change?
Does not fill on any setting, hot,cold, or warm. Does not spin or agitate in any cycle. Motor just stalls until thermal trips.
Washer Repair
