Jefe60
#1 Posted : Saturday, September 9, 2017 1:57:46 PM(UTC)
Jefe60
Need help locating where defrost timer is on this unit.
PNWDrew
#2 Posted : Saturday, September 9, 2017 8:12:44 PM(UTC)
PNWDrew
No defrost timer. It's an electronic control and it's up in the control box in the fridge.
Jefe60
#3 Posted : Saturday, September 9, 2017 9:44:37 PM(UTC)
Jefe60
Ok. Then if the freezer is not defrosting would you change the thermostat first?
PNWDrew
#4 Posted : Saturday, September 9, 2017 10:34:40 PM(UTC)
PNWDrew
If it's possible I'd test it first, while iced up so thermostat is closed. If there's a plug for the defrost element and thermostat at the evaporator a quick test for continuity (or resistance) through it would be all you need. If it is hard wired (and it probably is) you should be able to test up at control.
There's a wiring diagram in the parts list here.
Full diagram:
Frigidaire A01078804 Control,electonic,w/cover - AppliancePartsPros.com
Strip circuit:
Parts for Frigidaire FFHS2322MBHA: Wiring Schematic Parts - AppliancePartsPros.com
Also a visual check is sometimes enough, if the thermostat is bulging out or looks damaged that's a good enough sign.
If you don't have a multimeter to help diagnose, the thermostat is a good guess. It's cheaper than the board at least. That calrod style element is unlikely to fail.
Jefe60
#5 Posted : Sunday, September 10, 2017 11:28:01 AM(UTC)
Jefe60
Will do, thank you for the advice.
Frigidaire defrost timer location? (Refrigerator & Freezer Repair)
by jlanza 1/17/2009 1:26:14 PM(UTC)
