I am having the same issue. I swapped the yellow and green and I made sure the water line is not plugged and I just changed the water valve. I also manually reset the ice maker any ideas? AKA 626
i am having the same issue
Originally Posted by: craig n ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) i am having the same issue crag n What is the complete model number of the refrigerator?
Swapped the yellow and green connectors and water did run into the ice tray when i hit the water fill on the dispenser..
does that mean the ice maker is bad, or the water inlet valve?
