Recently my Vent Hood is noisy when I turned on the fan. So I checked the kitchen aid web site and it says it probably caused by Motor I did purchase. https://www.kitchenaidparts.com/...oud-or-noisy-KWCU205HWH1But the problem I face now is how to remove the fan. There are so many screws and there is no manual describing how the cylinder shaped ventilation is attached to the hood. I see the parts diagram but It does not tell me the proper way to disassemble. Some screw cannot take out due to the too narrow space. I took the photo inside my range food and I am not sure if I can simply unscrew the big (inside red in the picture) What is the best way to try clean the parts and replace for this model inside fan (cylinder shape) I looked at the Costco similar model but it seem to be much easier to disassemble this model make me headache. tako555 attached the following image(s):
This is so helping I almost stuck at removing the fan and this kinda helpful.
Originally Posted by: millyferry This is so helping I almost stuck at removing the fan and this kinda helpful. Hi So were you able to unmount or you have the same range hood? I have not even started (More than 4 month past) So we cook without Ventilation now. But I guess I have to start soon. Thank you for your feedback
