Burgerpimp
#1 Posted : Wednesday, June 7, 2017 10:14:27 AM(UTC)
Burgerpimp
My washer works through all cycles except spin. The door lock light comes on and door locks firmly, it agitates in both directions properly, the drain pump works and drains the water with a strong flow from the drain pipe. It just won't spin whether it is loaded or unloaded. If I try to start cycle with door open it gives me the open door warning. It's a front loading frigidaire gallery series, I'm not sure of the age as it was used when purchased. Any input would be much appreciated.
Burgerpimp
#2 Posted : Wednesday, June 7, 2017 2:29:38 PM(UTC)
Burgerpimp
Update
Found the diagnostic tests for the model and ran them. It went through all tests with flying colours (including the highspeed spin cycle) but returned an error code of e41 control board sees open door or something like that. I pulled the door unit and measured the resistance, it is 1300 ohms. Manual calls for 1500 ohms, new door unit enroute. Fingers crossed.
