keepitfromthedump
#1 Posted : Wednesday, May 24, 2017 2:18:27 PM(UTC)
keepitfromthedump
how do i remove the knob on the timer shaft?
i want to remove the timer from the control panel.
brobriffin
#2 Posted : Thursday, May 25, 2017 12:28:11 PM(UTC)
brobriffin
Man
model number is one digit short
keepitfromthedump
#3 Posted : Thursday, May 25, 2017 1:08:53 PM(UTC)
keepitfromthedump
110.6907603W10
sorry but after 50 years the numbers are not to clear
brobriffin
#4 Posted : Thursday, May 25, 2017 5:25:00 PM(UTC)
brobriffin
Man
If you pull on it should just slide off. As old as that unit appears to be you may need to slip a small screw driver under it to pry on it slightly.
thorning
#5 Posted : Friday, May 26, 2017 4:39:44 AM(UTC)
thorning
I am not familar with this unit but many timer knobs are held on the shaft by a hex nut on the shaft. This hex nut is accessed by popping off a small plastic cap on the surface of the timer shaft.
