guyster
#1 Posted : Monday, May 22, 2017 7:04:31 PM(UTC)
guyster
unit has bottom freezer drawer with icemaker inside bottom freezer compartment and frost builds up in front of ice drawer and across top of drawer
PNWDrew
#2 Posted : Wednesday, May 24, 2017 8:29:00 PM(UTC)
PNWDrew
Check the door seals for rips, or any reason they may not be sealing. Frosty ice is usually from warm air intrusion. The pattern of frost usually points right at the spot where it is entering.
Also look for any reason the door may not be shutting completely, such as an item fallen off the back.
guyster
#3 Posted : Tuesday, May 30, 2017 5:34:22 PM(UTC)
guyster
thanks for the reply thats kinda what i thought as there are no defrosters in sides of freezer walls only the defrost heater around coils and its not icing up back there.very helpful
