4 Pages<1234>
CitadelBlue
#21 Posted : Saturday, April 8, 2017 10:51:16 AM(UTC)
CitadelBlue
The master control board installed this morning. So far NOTHING .....
CitadelBlue
#22 Posted : Monday, April 10, 2017 5:28:49 AM(UTC)
CitadelBlue
Master control board didn t help ..
Power supply board ordered this morning.
CitadelBlue
#23 Posted : Thursday, April 13, 2017 6:59:18 AM(UTC)
CitadelBlue
Been working this issue for over a month.
Power Supply board installed.
$760 spent.
Waiting for ice ..... maybe
CitadelBlue
#24 Posted : Thursday, April 13, 2017 4:55:20 PM(UTC)
CitadelBlue
673 views ....
10 hours since I installed the power supply ... still no ice .......
Read on another post about a possible broken wire that comes up in the heavy harness with the water supply tube at the bottom of the freezer at or near the bottom hinge ..... Anyone have an insight as to how to find the broken wire that is wrapped in heavy cloth sheathing?
CitadelBlue
#25 Posted : Saturday, April 15, 2017 10:31:44 AM(UTC)
CitadelBlue
After 27 days ... 6 parts ordered (Solenoid valve, both emitter boards, ice maker, master control board and power supply board), 1 pro service call and 734 views on this forum, my ice make is still not working ........BUT there are a few wires wrapped in a cloth sheath (actually there are 2 of them and 2 water hoses) running under the freezer cabinet and into the bottom hinge of the freezer door and up the door. Underneath, the freezer cabinet is a connector .... THAT connector has a short in it due to movement as the freezer door is opened and closed. Its a solid/poured connector, poorly designed/secured in m opinion. All I did was jiggle the wire and I heard the water valve for the ice maker kick in ........ Its a tight space working between the kitchen floor and bottom of the freezer cabinet. The harness is NOT sold separately -- it come with a new freezer door.
So I'm back to the drawling/idea board for this one.
t189dms
#26 Posted : Monday, May 8, 2017 11:17:46 AM(UTC)
t189dms
Hi all,
Well, the ice maker was replaced and that did not correct the situation. The service guy then replaced the smaller of the two (the one on the right) circuit boards. After turning the power back on the LED lit up, but a few minutes later went out once again. He just returned today, swapped the old and new ice maker, the old and new circuit boards. The LED lit once again and after a few minutes went out again. I asked him how he knew that the smaller of the two boards was the issue and he gave me some vague response about the bulb appearing burnt. A few hours later I turned the breaker on and off once again and the LED lit for a few minutes and then went out. Still nothing.
I questioned the tech about the process of running diagnostics and he said that he was unable to do any such thing. So I said, you are just replacing parts based upon the probability that one of them are bad. Basically that's it. He said that if they returned the parts to the parts center that they might run tests to see if they are bad, but there was nothing he could do.
Told him that if there is no ice by tomorrow, I wanted him to reinstall the original parts and we would probably end up replacing the refrigerator....
t189dms
#27 Posted : Monday, May 8, 2017 11:19:06 AM(UTC)
t189dms
If you are still willing to send me the extra boards, I would give them a try to see if it would help. Thanks
CitadelBlue
#28 Posted : Monday, May 8, 2017 12:11:44 PM(UTC)
CitadelBlue
Originally Posted by: t189dms Go to Quoted Post
Hi all,
Sounds alot like my issue above ..... i suggest you get down on the floor and remove the small grill covering the very bottom of the fridge and freezer. It pops out, but you will have to have the fridge a nd freezer doors open. After doing that reach under there and jiggle the wiring harness that comes from the back of the freezer to the bottom hinge ... i heard my solenoid kick in the fill the ice maker .... if you get the same result... you and I have the same issue... a short in the wire .. close to the connector. I havent gone much further with my repair..... but got it on my to do list. Good luck.
t189dms
#29 Posted : Wednesday, July 12, 2017 10:54:49 AM(UTC)
t189dms
Just checked the board and noticed your recommendation regarding the connections and wires. (I had not received and email notification regarding your comments.)
Removed the grill and manipulated all three wiring plugs that are visible. No change in operation. The solenoid did not start up. No ice. No luck.
Interesting that there have been no comments or suggestions from any of the pros on this service.
Oh well. We did get a refund from the service company parts less the service fee.
swilly43
#30 Posted : Tuesday, July 31, 2018 10:33:11 AM(UTC)
swilly43
Wow, I have a similar issue with my Kitchen Aid built in that uses the same parts. I have replaced the ice maker with no luck an am now looking at the LED boards. Did either of you ever get this resolved or did you buy a new fridge? Seems so simple.
Guest (5)
4 Pages<1234>
