My Whirlpool Duet stopped working today. Error code F09 / E01. I used a shop vac to remove the water out of the drain lines (no problem). While there was some lint / debris build up, nothing that indicated a clogged line. So I tested the machine again and found the same issue. I opened the machine and removed and cleaned the drain filter. While I had access, I pulled the pump (which was very warm) and tested the motor (Askoll M75). I found continuity and a resistance of 17.4 Ohms. The impeller isn't blocked and will turn. So I tested the power to the motor and found 118 volts. My instinct is this motor is going bad.
Questions: 1. Is 17.4 Ohms too high for the pump motor? 2. If so, does anyone sell just the pump motor and not the entire assembly?
