Does anyone know about a bosh model # shx46a It will not drain. Can I test for this before ordering parts
Originally Posted by: jeremydfaust ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Hi, Thanks for the info. My 2006 SHE45 had the heater prong burnt out in the control module as did most of the models in this thread. I'd like to report that all is working great with the rather quick and painless repair.
Thanks again.
Burnt in Buffalo I'm having a similar issue with my she45m05uc/50. Based on the symptoms (abnormally long runs, lukewarm wash etc) it seems like it could be a burnt out solder joint connection. Unfortunately I got as far as the control panel cover. I was able to partially open it, but the design is different than what is mentioned in this thread and in the guide i followed below. One side of it doesn't even appear to be able to open despite the back being hinged. I'm afraid of using any more force than I already have for fear of breaking the cover. Through the portion i was able to open, i was able to view most of the board. As far as I could tell, I couldn't see any damaged connections. However, I can't be 100% certain. Does anyone have any advice on how to open my particular model's cover? Or thoughts on possible other causes of what is happening? Thanks, Kelvin Oh, also the Error Code I get when hitting the 2 mode buttons + Power is: C6 I haven't come across what that means. Bosch SHU43 Dishwasher Repair - Dishwasher keeps running (Stuff)
Very likely you would need to remove the outer door panel fist. Try to follow the instructions from attached file.
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Very likely you would need to remove the outer door panel fist. Try to follow the instructions from attached file. Hi Gene - Thanks for the reply! I actually did remove the outer door panel as well as separating the fascia console from the frame. However I there were no tabs as far as I could tell that would allow me to separate the control module from the frame. And I was unable to open the control module cover completely, as one side of it didn't even appear to have an opening all the way around. I will try to post some pictures when I get home tonight. Any thoughts on what the code C6 means?
Here are the pics of my washer's control module cover. I can't figure out how to get it open, as mentioned: Originally Posted by: kli ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Hi Gene -
Any thoughts on what the code C6 means? kli attached the following image(s):
How does it look from the other side of the metal panel?
Here are the pics Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) How does it look from the other side of the metal panel? kli attached the following image(s):
Hm... after staring at the pics now, I just noticed that maybe i can push the tabs in from the left side to release it thru the opening? Originally Posted by: kli ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Here are the pics
