jppablo4987
#1 Posted : Monday, April 24, 2017 11:40:39 AM(UTC)
jppablo4987
Washer goes through the most of the cycle but stalls/stops at rinse cycle. Will work again if I manually advance the timer. I'm assuming that the timer needs to be replaced but want to get some feedback before buying a new part. Thanks for any advice.
#2 Posted : Monday, April 24, 2017 1:26:37 PM(UTC)
Looks like you are on the right track and the cause of the problem is a faulty timer. You can order the part from AppliancePartsPros.com with no any risk because if the new part would not fix it, you can return it even if was installed.
The timer Part number: AP2045882
Here are the break down diagrams for your GE washer Model WPSR3120W0WW
GE Washer repair/ Possible Switch (Washer Repair)
by Pia 3/28/2013 9:14:51 AM(UTC)
GE Washer Repair (Washer Repair)
by peachesandolivia 11/11/2010 6:33:16 AM(UTC)
GE washer repair (Washer Repair)
by khesson 3/5/2009 11:19:02 AM(UTC)
