4 Pages<1234>
CitadelBlue
#11 Posted : Friday, March 31, 2017 4:27:11 AM(UTC)
CitadelBlue
259 views. Anyone have any other suggestions?
CitadelBlue
#12 Posted : Saturday, April 1, 2017 4:16:46 PM(UTC)
CitadelBlue
Ice maker replaced this morning and still no ice. Sooooooo ....... its back to the drawing board.
CitadelBlue
#13 Posted : Monday, April 3, 2017 2:40:41 PM(UTC)
CitadelBlue
Originally Posted by: CitadelBlue Go to Quoted Post
Morning Gene .... my background ice maker issues are posted above..... in summary
I have a working water dispenser
I ve replaced the double solenoid valve, both emitter boards, and the ice maker.
I see a red LED from the left emitter board when the ice bin is in place. It does go out after a few minutes.
I ve jumped the ice maker (to simulate ice harvest) but it doesn't cycle.
Thoughts?
Hello.
What is the part number of the new ice maker?
Please, describe how did you jump the ice maker.
Pull the ice maker out. Looking at the ice maker head from the mold and heater assembly (back of the head), locate the slot for the shut-off arm (old design) in the left upper corner of the head. This slot is for the on-off switch inside the head. Using a flat screwdriver, try to turn it counterclockwise. Put everything back together and give it a try.
Good luck.
Ice maker P/N: AP6017832
Jumped the ice maker to harvest ice
1. Turned power off at circuit breaker
2. Removed ice bin
3. Removed inner door cover/housing that covers ice maker (2 philips screws)
4. Removed ice maker head cover
5. Inserted wire in holes T and H to harvesting ice (Picture)
6. Reinserted ice bin to close switch on emitter board
7. Turned power back on
8. Since the inner door panel is off I closed the switches that extinguished the interior lights
9. Watched and waited ....... nothing...
On-off switch inside the head (Picture)
Inserted screwdriver. Switch turns clockwise then counterclockwise.
Nothing .....
347 views ...... Thoughts?
CitadelBlue attached the following image(s):
CitadelBlue
#14 Posted: : Tuesday, April 4, 2017 7:42:49 AM(UTC)
CitadelBlue
Called a pro ..........
He is pretty sure its the main control board ..... $222 including shipping.
Ever hear of the money pit ..............
I'm selling apples and pencils on the street corner to pay for my ice making attempts ........
t189dms
#15 Posted : Tuesday, April 4, 2017 5:59:25 PM(UTC)
t189dms
I'm also about to order the LED boards for our Whirlpool which is also not making ice. Hate throwing money at parts without being able to actually test the suspect parts to determine if that is the issue or not. Gets expensive really quick.
CitadelBlue
#16 Posted : Tuesday, April 4, 2017 6:03:14 PM(UTC)
CitadelBlue
What are the issues with your ice maker? These boards basically monitor the ice in the ice bin and tell the ice maker when to make ice.
I'm expecting my control board to be delivered on Thursday. If that will solve my issue I will have a spare /new set of emitter boards to give you (I purchased a set and was given a set after ordering). The boards I have are W10296530 and W10180607. If they fit your set up ..... let me know. They are yours .....
Ken
Ken.Kmiec@cox.net
CitadelBlue
#17 Posted : Friday, April 7, 2017 4:01:32 AM(UTC)
CitadelBlue
Control board arrived at 700 last night via Fedex. I must have been the last delivery. Any way, Appliance Parts Pro get zero stars for packaging. This is the 3rd part I've ordered and Appliance Parts Pro still must have a shortage of bubble wrap and tape. Basically, a $213 board in a box, but at least this one was in a clear plastic bag. Haven't installed it yet. Need to empty part of the frig to reduce weight so I can pull out the frig and also lay down a 1/4 inch sheet of plywood to protect the floor. I am hoping this solves my no ice issue and I can then return the other parts.
t189dms
#18 Posted : Friday, April 7, 2017 1:55:33 PM(UTC)
t189dms
Thanks for the offer. I've called a repairman and he says the ice maker needs to be replaced. The part has been ordered. Will let you know once it arrives and we have ice....
CitadelBlue
#19 Posted : Friday, April 7, 2017 5:40:54 PM(UTC)
CitadelBlue
I may have a spare ice maker as well....
t189dms
#20 Posted : Saturday, April 8, 2017 6:38:44 AM(UTC)
t189dms
Thanks for the offer, but I've already ordered it....
4 Pages<1234>
