efolbrecht
#1 Posted : Monday, March 20, 2017 3:53:23 PM(UTC)
efolbrecht
Wirlpool Cabrio Top Loader
I had to remove the inner "spinning" basket. Now I am trying to install it back but I am not able to get it more than halfway down the drive shaft. When I put pressure on the tub, it just sways on the suspension rods.
Should it be this hard?
Thanks.
efolbrecht
#2 Posted : Tuesday, March 21, 2017 8:20:13 AM(UTC)
efolbrecht
Solved: I applied WD40 to shaft and tube of the tub and pressed down real hard. I blocked the bottom of the shaft to take the weight off of the suspension rods.
