I purchased a suspension kit from this site and installed them this evening. The washer still gets a UL code when spin is around 9 minutes left. This happens even if nothing is in the washer. At slow spin it appears balanced but once it goes into a faster spin the washer acts like an unbalanced tire on a car. Since not the suspension kit, what do I need to look at next?
Joined: 6/13/2014(UTC) Posts: 781 Was thanked: 1 time(s) in 1 post(s)
dosmond please give us you model # for further assistance
The washer model in question is WTW6700TW2 SN CW5170460
A sign of bearing failure is what appears to be grease splatter under the machine. Inside the Rotor and against the under side of the walls. brobriffin attached the following image(s):
