Tfowler465
#1 Posted : Tuesday, February 28, 2017 1:56:52 PM(UTC)
Tfowler465
I'm working on a maytag front load washer that the second you plug it in, it trips the gfci. so I plugged it into a non gfci outlet and something popped in the main control board. I have a spare but don't want to put it in and ruin that one to. what is the most likely cause for this happening and how or what do I test to figure it out? the model number is MHW4300DW
PNWDrew
#2 Posted : Tuesday, February 28, 2017 3:02:47 PM(UTC)
PNWDrew
There are way too many variables to guess. Can you ID what burnt on the control? Look for the obvious burns or discolorations that would normally accompany a failed component.
A pic of the board front and rear out of the plastic housing might help.
Tfowler465
#3 Posted : Wednesday, March 1, 2017 5:38:02 AM(UTC)
Tfowler465
there were no visible burn marks that I could see on the control board. it makes me wonder if the control board was already bad to begin with.
PNWDrew
#4 Posted : Wednesday, March 1, 2017 8:15:40 PM(UTC)
PNWDrew
Your guess that the original board may have been bad is a good idea.
I'd say first check for any continuity between ground and either side of the plug. You can do this at the plug itself to start with. Something is shorted to ground and your goal is to track that down. Start with the noise filter unplugged to begin as close to the plug as possible.
This stuff can be a nuisance, If nothing is obvious and you have a working board you can always install it and use the gfci outlet again. Leave everything unplugged from the board initially, then plug things in one by one until something trips the GFCI outlet. Wear shock proof gloves or unplug the machine prior to each new connection. Hopefully the board survives the GFCI trip. It would suck to burn a 2nd board. If it's for a customer you might explain the risk and let them make the call about potentially frying an expensive part.
Maytag Front Loading washer making noise (Washer Repair)
by joefigg1 5/22/2023 2:33:53 PM(UTC)
Maytag front loading washer (Washer Repair)
by Guest 4/23/2023 1:47:52 PM(UTC)
Maytag front load won't stop draining and is locked (Washer Repair)
by Guest 2/5/2023 1:32:02 PM(UTC)
Maytag front load med5630 electric (Dryer Repair)
by Guest 6/18/2022 11:44:28 AM(UTC)
maytag front loader washer model# mhwe300vf00 (Washer Repair)
by Guest 9/26/2021 9:57:51 AM(UTC)
Maytag Front Load Washer Model MHW8000AW0 (Washer Repair)
by Lery 4/8/2021 8:31:13 PM(UTC)
MHWE550WJ01 Maytag Front Load Washer No Water (Washer Repair)
by alligatorous 7/27/2020 11:07:06 PM(UTC)
Maytag Front Loader not dispensing bleach or fabric softner (Washer Repair)
by Ron1404 12/18/2016 3:42:55 PM(UTC)
Maytag Front Loader FH (Washer Repair)
by MyNameIsNate 8/2/2016 2:09:50 PM(UTC)
Maytag Front Load Washer Leaking During Spin Cycle (Washer Repair)
by michelleyeo 12/11/2015 9:34:09 AM(UTC)
Maytag front loader washer will not extract water from clothes all the time (Washer Repair)
by jsegura525 1/1/2015 7:48:41 AM(UTC)
UNBALANCED load - Maytag front loader MAH7500AWW (Washer Repair)
by mrogge 10/1/2014 7:40:59 AM(UTC)
Maytag Front Load Washer (Washer Repair)
by dengchr 2/5/2014 7:24:25 AM(UTC)
Maytag front loader 2000 series problem (Washer Repair)
by amarilloscout 10/11/2013 7:16:35 PM(UTC)
Maytag Front Load Washer Thumping (Washer Repair)
by Papa_omero 9/25/2013 5:45:38 AM(UTC)
