Jlb86
#1 Posted : Friday, February 24, 2017 4:24:03 PM(UTC)
Jlb86
My Kenmore dryer timer will not advance and will not shut off unless I open the door. I'm wandering if I can fix it or if I just need a new dryer.
ThatGuy
#2 Posted : Saturday, February 25, 2017 9:32:09 AM(UTC)
ThatGuy
Your description is a little vague.
The timer will not advance in any of the cycles? Even timed dry?
Does it seem to be heating OK?
When it reaches the end of a cycle (lets say you turn the knob manually) It won't shut off and the only way to stop it is to open the door?
Jlb86
#3 Posted : Saturday, February 25, 2017 10:19:04 AM(UTC)
Jlb86
No the timer will notadvance on any setting. It dries just fine. But will not shut off unless the door is opened
ThatGuy
#4 Posted : Saturday, February 25, 2017 11:13:20 AM(UTC)
ThatGuy
In that case its most likely the timer. Probably has a contact welded together inside.
Jlb86
#5 Posted : Saturday, February 25, 2017 11:56:47 AM(UTC)
Jlb86
Where would I find a new part? Its an '80s model
ThatGuy
#6 Posted : Saturday, February 25, 2017 12:38:07 PM(UTC)
ThatGuy
Can you post your model number?
thorning
#7 Posted : Monday, February 27, 2017 4:29:11 AM(UTC)
thorning
You need to put in the model number to help identify the p/n of the timer. You can usually find it on this web site Appliance Parts Pros or an alternate location is ApplianceJunk.com . Dont be suprised if you find the cost is more than $100 in which case you should consider getting a new dryer.
GE gas dryer timer will not advance on Easy Care feature (Dryer Repair)
by MrsG 1/23/2015 5:38:59 PM(UTC)
Dryer timer will not advance (Dryer Repair)
by Brian7780 6/19/2010 7:23:44 AM(UTC)
Dryer Timer Will Not Advance (Dryer Repair)
by cyclone 1/15/2009 9:42:24 AM(UTC)
Dryer Timer will not advance in Automatic (Dryer Repair)
by kabgreen 5/10/2008 8:45:42 AM(UTC)
