Laura in Houston
#1 Posted : Sunday, January 29, 2017 2:11:16 PM(UTC)
Laura in Houston
The shaft from the knob to the oven control switch was sheared off accidentally, right at the knob, so some of the shaft is stuck inside the knob. I can't seem to find a replacement knob and switch.
Can we just use JB Weld or something similar to glue it back together? The oven was off when the shaft was broken, so it's not hard to match up the pieces.
Do we have to order a new switch instead, if that's not a reasonable repair process?
Are there matching replacement knobs available for a 20-year-old gas range and oven?
ThatGuy
#2 Posted : Sunday, January 29, 2017 9:00:34 PM(UTC)
ThatGuy
Is it a knob or a push button?
I found this. Is this the right computer/clock for your range?
GE WB27T10469 Clock - AppliancePartsPros.com
If not, could you take a pic of it and post it?
Laura in Houston
#3 Posted : Monday, January 30, 2017 6:41:24 PM(UTC)
Laura in Houston
No, it's not the clock. It's the oven knob. The knob turns, but doesn't push in. I'll try to post a pic, but I haven't done anything on forums in forever, and I've forgotten how.
ThatGuy
#4 Posted : Monday, January 30, 2017 6:50:12 PM(UTC)
ThatGuy
Laura in Houston
#5 Posted : Monday, January 30, 2017 6:57:35 PM(UTC)
Laura in Houston
These 2 pics show the front of the oven, and the knob and where it used to be attached to the rest of the shaft.
Laura in Houston attached the following image(s):
Laura in Houston
#6 Posted : Monday, January 30, 2017 6:59:09 PM(UTC)
Laura in Houston
Here's a pic that shows the front of the knob.
Guest (5)
