AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Whirlpool washing will only spin - humming otherwise
Hi All, Last night went to check washer and selector dial knob was pointed to Rinse but nothing was happening other than a humming noise. I manually advanced knob to spin and that worked fine. It then occurred to me that the clothes probably had had not rinsed and and thought I'd better try a full wash cycle again. It's doing nothing but spin and only when I turn the dial manually to that position. This is true for all the wash modes around the dial - only spin will work.
I know it filled and ran thru the cycle that initial time until it got stuck at rinse and I noticed.
I removed the supply hoses and made sure the input screens were clean and I had good water pressure.
Anything I can check first to diagnose before I start throwing money at parts? I have a voltmeter and tools and I'm pretty handy if I know what to look for.
Thanks for the help in advance!
Joined: 7/27/2010(UTC) Posts: 1,395  Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
It sounds like you're not getting any water. Have you tried warm or hot settings?
The rinse is almost always cold water, you could have a bad cold valve,
Is the humming noise coming from the water valves?
Hi, thanks for responding. I tried all temperatures. It will not fill at all on any temp setting. I will see if I can isolate the humming this weekend and report back.
I pulled the back of the machine off and the humming noise is coming from the valve.
What kind of voltage should be at the terminals? If I fill the machine manually and it runs, is it the valve for sure? I may try that tonight.
Washer Repair
