wjbertrand
#1 Posted : Sunday, December 18, 2016 11:31:25 AM(UTC)
wjbertrand
Just the last 3 days, we have been finding ice frozen on the top shelf and sometimes the other shelves and down on the floor of the refrigerator section. The temperature is set to the normal setting and stuff in the fridge seems to be at the right temperature. I suspect a frozen or blocked defroster drain. Would like some advice accessing that or redirection if my suspicions are incorrect. The unit is equipped with an ice maker that seems to be working properly.
wjbertrand
#2 Posted : Sunday, December 18, 2016 1:38:04 PM(UTC)
wjbertrand
OK, I think I figured it out. The drain hole below the narrow aluminum pan (that sits below the coils) and the pan itself were completely filled with ice. Tried chipping some of the ice out of the hole and then dumped a 1/4 teaspoon of salt into the defrost drain. That worked really fast as by the time I'd heated up some water and poured it into the pan, it was already flowing to the pan. I poured a good two cups of hot water through the drain to make sure it was flowing freely and that all the salt was washed out. Put it back together and will keep my fingers crossed.
Update: three days later and the refrigerator shelves have remained dry. i think it's fixed.
