bartbill
#1 Posted : Wednesday, November 16, 2016 10:51:46 PM(UTC)
bartbill
Power went off. Then when we reset the clock we heard a "pop". Now we have nothing. The Digital Electronic Oven Display is blank. However, the oven light is working. So there is power to the unit. There is 120 volts to each connector on the control block. There is a bank of three relays (I think) beside the electronic control card. (not mounted on it)
Checked continuity of the heating elements - ok.
There is a small unit with a red reset button on top near the control block, it seems ok. I think it is the Thermal control that prevents overheating.
Could as blown relay make the "pop". Found the relays #318111501.
I think the control card is hard to find and I dont have the Frigidaire part #.
Any thoughts would be much appreciated. This is my mother's wall oven and seems like a very fine oven. Think I would repair that buy a new one.
ThatGuy
#2 Posted : Thursday, November 17, 2016 11:23:39 AM(UTC)
ThatGuy
Relays burn up, capacitors can go 'pop'. So can transformers.
I'd check the computer board for blown caps and burnt traces. There are people that rebuild these.
The part is no longer stocked anywhere, but you might be able to find a used one. part no. 318010700 ?
I'd have the original rebuilt.
bartbill
#3 Posted : Thursday, November 17, 2016 11:53:14 AM(UTC)
bartbill
Thanks much. I'm online now looking at rebuilders. Any you would recommend -or to avoid?
Whirlpool double oven RBD305PVS02 no display, no heat, lights work (Oven Repair (including Ranges and Cooktops))
by Guest 1/5/2022 7:05:37 AM(UTC)
Whirlpool Double Oven, RBD305PRS00, no display, oven dead (Oven Repair (including Ranges and Cooktops))
by steveg_nh 12/31/2021 7:23:33 AM(UTC)
No Display or Oven Light - GE Monogram ZGP304NR4SS (Oven Repair (including Ranges and Cooktops))
by Furgus 8/22/2021 10:11:09 AM(UTC)
GE Profile PSRS6PGZADSS No Lights, No Display Panel (Refrigerator & Freezer Repair)
by ablundon 5/5/2021 10:43:50 AM(UTC)
Fridge not working, No cooling, and no display (Refrigerator & Freezer Repair)
by thepr1nter 1/13/2021 8:22:08 AM(UTC)
Thermador double oven no display (Oven Repair (including Ranges and Cooktops))
by daiwa0411 10/8/2020 7:12:03 AM(UTC)
No Display, but Oven works and buttons beep (Oven Repair (including Ranges and Cooktops))
by kevinlampert 10/5/2020 2:11:56 PM(UTC)
Samsung DV42H5200EW/A3 No Display (Dryer Repair)
by caveman61 7/18/2020 7:28:59 AM(UTC)
Whirlpool Duet-No Display or Button function (Dryer Repair)
by floatinghead 6/8/2019 6:55:48 AM(UTC)
Not heating/No Display until burner switch turned on (Oven Repair (including Ranges and Cooktops))
by MattoxL 2/7/2017 6:16:27 PM(UTC)
Jenn Air Combination Wall Oven - NO Display?? (Oven Repair (including Ranges and Cooktops))
by jtharmon 12/19/2016 5:06:52 AM(UTC)
GE Refrigerator - No display indicator and cooling (Refrigerator & Freezer Repair)
by coolvir 11/15/2015 6:49:44 PM(UTC)
No Display (Oven Repair (including Ranges and Cooktops))
by shaneast1 10/4/2015 8:08:29 AM(UTC)
by gschvach 9/20/2015 5:57:03 AM(UTC)
Samsung Range no Display (Oven Repair (including Ranges and Cooktops))
by Windy_City_Lee 9/19/2015 12:59:11 PM(UTC)
