Press preheat. Set oven temperature (example 400 degrees). Heats up normally showing temperature increasing. When temperature indicates 400 it beeps. Put food in oven. Can observe the lower heating element cycling on and off to maintain set temperature. All normal so far. A while later open oven to check if food is ready. The food is not ready and can feel the oven is not as hot as it should be. Close oven, press cancel, press bake. Set oven temperature 400 degrees. Temperature indicates much lower, how much varies but have seen as low as 315 degrees. Oven again heats up normally as before, but again will not maintain the temperature. The problem is the oven is not maintaining the set temperature. Please recommend what I should do.
Did you resolve your issue? We have the exact same problem with our duel fuel downdraft unit (JDS9860CDS02). We have spent close to $150 having the electronics replaced, but have the same issue. It does seem sporadic. We don't seem to have problems in convection mode, but we might just not recognize the issue since we don't use convection that much.
