rgoslo
#1 Posted : Wednesday, November 9, 2016 1:19:23 PM(UTC)
rgoslo
dryer starts, the drum is turning, and it gets hot. after five minutes dryer cuts off. it will start right back up then cuts off in about 5 minutes. unit is clean and exhaust line is clear. how can I fix?
brobriffin
#2 Posted : Thursday, November 10, 2016 8:06:39 AM(UTC)
brobriffin
Man
Its very likely the motor is bad and overheating. Here is the part you will need.
GE WE17X22217 Kit Motor and Pulley - AppliancePartsPros.com
rgoslo
#3 Posted : Thursday, November 10, 2016 11:39:07 AM(UTC)
rgoslo
When I Run The Dryer In The Cool Down Mode (no Heat) It Does Not Cut Off. Would It Still Be The Motor?
brobriffin
#4 Posted : Thursday, November 10, 2016 12:25:29 PM(UTC)
brobriffin
Man
How long will it run in that mode?
rgoslo
#5 Posted : Friday, November 11, 2016 6:07:26 AM(UTC)
rgoslo
dryer runs full cycle ( 20 min)
brobriffin
#6 Posted : Friday, November 11, 2016 6:56:46 AM(UTC)
brobriffin
Man
No if it only shuts down in heat mode then the motor is likely ok.
Have you tried in other modes like delicate mode (low heat)?
It may be a problem with the control board.
GE WE4M296 Electronic Board - AppliancePartsPros.com
I doubt its an issue with the thermostats as they only shut down the heat not turn off the dryer.
Its not the thermal fuse it doesn't reset.
rgoslo
#7 Posted : Monday, November 14, 2016 5:29:19 AM(UTC)
rgoslo
yes, in all heat modes it shuts off.
brobriffin
#8 Posted : Monday, November 14, 2016 1:16:50 PM(UTC)
brobriffin
Man
I would be inclined to say the control board is having power issues. Try replacing it.
