tomwing
#1 Posted : Tuesday, November 1, 2016 8:54:22 AM(UTC)
tomwing
Touch pad will let you select everything but will not change numbers by pressing the up/down arrows. It seemed for a while you could tap it a bunch and it would work - now not at all so i think it is the pad?
Dacor Range/Stove/Oven Touchpad 62676B
Would you agree? thanks!
ThatGuy
#2 Posted : Tuesday, November 1, 2016 12:19:00 PM(UTC)
ThatGuy
You might try disconnecting the flat ribbon cable and then reconnecting it. Sometimes its just a bad connection.
Your model number didn't come up on this site, but it might be the touch panel.
tomwing
#3 Posted : Wednesday, November 2, 2016 5:05:14 AM(UTC)
tomwing
You were so right! - last eve before I got this I took the part off (including the ribbons) and got the numbers off of the part - then decided to put it back in. Voila - works again. thanks so much you had it right...
