Hi. I replaced the drain pump on my washer because of the code I was getting after it was shutting off before starting any cycle. It now works, but when it fills up it leaks. Upon further inspection I found that it is leaking whenever it adds water to the detergent side, and not from the bleach or fabric softener side. Can anyone please help me with this so I don't end up buying parts I don't need?
I took the top off while it was filling up. Nothing is leaking that I can see from the top. So it's got to be something from the bottom. It only happens when it adds water. It doesn't leak out completely but enough to cause concern. It's not from the wall or the connection from the wall to the machine.
