My apologizes, I was distracted by a call and didn't look them up here since I was on another site. Never even realized I posted from there instead of here.
No worries; sadly I allowed the unit to completely defrost, so I was not able to check what you suggested, but it's back on now. I should mention I set the unit to do a defrost cycle, by manually clicking the light switch 5 times fast last time and it took far longer for it to clog with ice. I've not done that this time, though that back panel is still off.
Once you get a good frost pattern on the evaporator, run a manual defrost again and watch to see if the heater gets hot and melts the frost. If it does, you need a new electronic defrost timer. If not, check the limit and heater as previously suggested to determine which one has failed. It will take a couple minutes for it to start defrosting once manual defrost is started. It should have thawed it all out within half an hour. Hope this helps!
I made sure the defrost cycle was selected, and nothing happened, the frost continues to grow (damned fast this time). I gave it a day and a night after I selected defrost, because the semi-clear instructions on how to do so suggest it needs that much time. I know it was enabled because one selected, the unit's sound changes. I'm looking for something to let me measure the ohms. I'll look at the manual when I get home to see what the parts to be measured look like.
The Compressor Start Relay. The start relay is a small device mounted to the side of the compressor. It provides power to the winding for a split second at start up to help the compressor run. The other component that may have failed could be the Start Capacitor. The start capacitor acts almost like a battery to give the compressor a small boost during power up.So cheque it .
Joined: 7/27/2010(UTC) Posts: 1,395 Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
Originally Posted by: Dean Haustead The Compressor Start Relay. The start relay is a small device mounted to the side of the compressor. It provides power to the winding for a split second at start up to help the compressor run. The other component that may have failed could be the Start Capacitor. The start capacitor acts almost like a battery to give the compressor a small boost during power up.So cheque it . Dean is a spambot with 29 posts. I sure wish someone would delete him.
