I see water pooling in the bottom cavity of the rubber door boot after machine has drained. Water is not in the rub itself, but inside the door boot. Is this normal? Thanks
Topic should have been "water sitting in bottom of front door rubber boot ring"
Sorry
Without seeing a picture I would say this is normal. If you look closely you will even see that the door boot has a few holes in it for water drainage.
